Hotpoint WD420 problems…
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Hotpoint WD420 problems…
Viewing 4 posts - 16 through 19 (of 19 total)
  • #232943
    Re: Hotpoint WD420 problems…
    Triac is a component on the main PCB, this one controls the motor.
    These boards can go AWOL if the wind changes. 😥
    Dinie
    I have a similar problem, but with less lights. 🙁 The power light is flashing rapidly and the “Drying High Heat” and “Reduces Creases” lights are also flashing. We’ve recently replaced the thermostat (about 2.5 weeks ago now) as the dryer was failing to dry. This solved the problem and the machine has been working fine until last night. First of all, the door refused to “unlock” after finishing a wash. I ran the wash again and the door opened. This morning, I’ve run another wash and now the above mentioned lights are flashing. Do I too have an NTC problem or has something just come loose after the thermostat replacement?
    Thanks for reading.
    Di.
    #232945
    Best to give us the lights by number from top down, however if it is lights 1+2 then you have a communications error. The two PCB’s are not talking to each other. It could be that you have disturbed some of the connections, if all connections are OK then it may well be the main PCB that has failed.
    Dinie
    Thanks for the response. It was indeed lights 1 and 2. I had earlier tried switching the machine off and on again to no avail. However, I turned the machine off to 10 minutes, left it, and switched it on again and the lights cleared and I was able to start the next wash.
    Thanks again for the help;
