Hotpoint WD420 pump filter access Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Hotpoint WD420 pump filter access This topic has 1 reply, 1 voice, and was last updated 19 years, 5 months ago by chili. Viewing 2 posts - 1 through 2 (of 2 total) Author Posts November 22, 2006 at 1:16 pm #22783 chiliParticipant Can anyone tell me how to access the drain pump pre-chamber on my WD420? The programme is hanging at pump out so I suspect the chamber is full. This is an early version of the WD420 which does not have the easy access behind the kicking board which is, apparently, featured on later versions. Thanks. November 22, 2006 at 2:28 pm #196139 chiliParticipant Re: Hotpoint WD420 pump filter access No worries, it’s sorted. I found an earlier post describing how to remove and clean the drain pump assembly. There was no trace of the expected hair/fluff ball but after putting it back together everything works fine! I guess the pressure switch had tripped somehow and it got reset by my fiddling. Author Posts Viewing 2 posts - 1 through 2 (of 2 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
