Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › hotpoint wd420 washer drier flashing lights!
- This topic has 11 replies, 6 voices, and was last updated 19 years, 8 months ago by
andrew3556.
August 4, 2006 at 12:30 pm #19676
andrew3556
ParticipantHello,
my washer drier has started to play up. The on/off button led is flashing fast and the reduce creases and time saver button leds are flashing slowly. The door is locked and the drier shaded pole motor is running. Can anyone tell me what the fault code is that is flashing up and if it’s fixable by myself (machinery maintenance tech myself, but not with whitegoods).Any help much appreciated.
August 4, 2006 at 1:31 pm #184035Dave_Conway
ParticipantRe: hotpoint wd420 washer drier flashing lights!
Counting from the top down (1 to 5), which of the lights on the left are flashing Andrew ?
August 4, 2006 at 2:20 pm #184036andrew3556
From the top, the 2nd one down and the 4th
August 4, 2006 at 3:04 pm #184037Dave_Conway
F05 then, pressure system related.
If you use the search here:
http://www.ukwhitegoods.co.uk/modules.p … ile=search
And search for F05 – pick out the Indesit and Ariston one’s, they are all the same controls and the error codes are the same 😉
August 4, 2006 at 4:36 pm #184038andrew3556
cheers Dave
August 7, 2006 at 5:27 am #184039andrew3556
That sorted it . I found a hair bobble trapped in the impeller of the drain pump.
August 15, 2006 at 4:16 pm #184040sara_elle
Hi, I have the same problem with my hotpoint wd420 with the on/off button flashing rapidly and the 1st, 2nd and 4th buttons on the left flashing. Have you got any idea what this could be?
many thanks
sarahAugust 15, 2006 at 8:49 pm #184041Penguin45
1,2+4 flashing indicates a problem with the dryer section temperature control (common) or the blower motor (uncommon).
Power off if investigating.
Penguin45.October 18, 2014 at 12:49 pm #184042gasket
Hi Guys,
Would anyone be able to tell me what the 2nd,3rd& 4th flashing lights represent , As i have this problem
October 18, 2014 at 2:09 pm #184043iadom
ModeratorOctober 18, 2014 at 3:39 pm #184044gasket
Thanks for the quick reply, for a 10 year old machine, would u just suggest replacing the machine
October 18, 2014 at 4:18 pm #184045iadom
ModeratorRe: hotpoint wd420 washer drier flashing lights!
10 years out of one of these is very good going. A new pcb will cost £100 and need a £20 smart card and a £103 card reader to programme the pcb. That is if you wanted to attempt the repair yourself. you could try and get the pcb repaired but in all honesty I think you should give it the last rites. 🙁
