hotpoint wd420 washer dryer drying problem
Home Forums Public Support Forums Help And Support Washing Machine Help Forum hotpoint wd420 washer dryer drying problem
  • #56868
    lee39
    this machine is turning out to be a thorn in my side.after sorting the spinning with water problem thanks to iadom(top man),it now runs ok but when drying no matter how long it drys items come out dampish.i know heater works as items are hot to the touch at end of cycle,any ideas greatly appreciated.
    #329123
    Re: hotpoint wd420 washer dryer drying problem
    The first thing to check is the dryer chamber filter.
    This is far more difficult to access than the pump filter.
    It is at the very back of the dryer chamber. The whole of the dryer assembly needs to be removed, stripped and cleaned. If it does have the small meshed filter at the back then removing the mesh part completely and discarding it is often the best option.
    Having said that, if the filter is clogged it usually throws up error messages or trips the dryer TOC.
    #329124
    lee39
    thanks for prompt reply will do that tomorrow and report my findings
    #329125
    lee39
    dryer chamber was fairly clean but the mesh filter was clogged seems to be drying better now,on the same machine what would cause it to vibrate severely during spin cycle.i first thought it was out of balance but it does it on every load.i noticed it puckers the door seal also,ive checked the dampers they seem fine
    #329126
    helo_75
    loose front weight?
    #329127
    lee39
    front weight is tight
