Hotpoint WD420 Wiring diagram for module hotcold fill model
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Hotpoint WD420 Wiring diagram for module hotcold fill model
  • #20049
    jenson
    Hi has anybody have a dia of the module connects on this model as
    a customer has disconnected the single wires which are not marked all
    the all the blocks of connectors are keyed thanks Jenson
    #185579
    Re: Hotpoint WD420 Wiring diagram for module hotcold fill mo
    Check your e-mails.
    PS. Manual is part number 5407170 😉
    Just spotted you want the H/C fill model 😳
    Connecter blocks still fit in same place, block J8 ,eight connector block just has two less wires on the info I sent you.
    #185580
    Did you receive the info I sent jenson?
    jenson
    iadom wrote:Did you receive the info I sent jenson?
    yes Jim i have the module connected corectly know
    but have a prob whick i need to spend more time on
    thanks for the info
    jenson
    #185582
    Don’t keep it to yourself, remember, a problem shared is a problem halved, it can also lead to more info for all the forum trade members.
