Hotpoint WD420 Won’t Start
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Hotpoint WD420 Won’t Start
  • #27161
    GinaG
    Tonight I was washing a duvet, pillowcases and a sheet. I had it on the wash setting then dryer setting (normal setting, not the high heat one). I checked it a couple of times and the dryer was going fine. After the time was up I checked on it, and the start/stop button was flashing quickly along with the ‘drying high heat’ and ‘reduce wrinkles’ lights. This never happened before. Now when I try to start it, these lights just come on and start flashing quickly and it won’t start. This washer is around 2 years old. I know the dryer’s working because the sheets etc were warm when I took them out.
    Help!
    #212839
    Re: Hotpoint WD420 Won’t Start
    Can you tell us by number from top to bottom which lights are flashing?
    PS. Surely you mean Reduced Creases. 😆
    #212840
    GinaG wrote:Tonight I was washing a duvet
    I hope you mean a duvet cover?
    GinaG
    OK, from top to bottom, it’s buttons 1 and 2 (out of 5 buttons). And the on/off button blinks as well, all at the same time.
    And yes, I was washing a duvet COVER. :rolls: My goodness if I was washing a duvet I’d really have problems!!
    Reduce wrinkles…reduce creases…same thing! 😆
    #212842
    Not goods news really, Fault code is F12, which is supposed to signify a communications error between the two circuit boards, could just be loose connections but could also be faulty control board. 😥 The Indesit electronics used in these machines do have a reputation of being somewhat unreliable. Be sure to remove the mains plug if you intend to investigate and remember that you are covered for parts for five years, so if you send for Hotpoint/Indesit then you will only pay the labour.
    Worth checking that none of the buttons are stuck in as well.
    GinaG
    Oh great. Thanks for the information, I appreciate it.
    #212844
    GinaG
    😀 Actually..my husband thought maybe it was overheating and this triggered a cutoff switch of some sort. So he took the top off, disconnected a few things (not sure what) reconnected them, and voila! The washer works again! Whew!!!!!!!!!
    #212845
    iadom wrote: could just be loose connections
    #212846
    GinaG
    Ok, ok, you DID say that. 😉 I was expecting the worst, that’s all!
    Thanks for your help!
    #212847
    helo_75
    for some strange reason, ive had a few ‘f12’ faults
    ive unplugged them , left them 15 mins and plugged em back in, its a communication error, so the machine tends to reset itself.. always the first thing i try…
    hope this helps someone, somewhere
