Hotpoint WD420G
  • #47983
    lyndy
    Hotpoint WD420G
    If selecting spin programme, door locks, starts to spin ok for 20 seconds, the on off indicator flashes rapidly and then the rinse hold and time saver lights flash steadily together. The drain pump switch is on and the inlet valves let water in.
    Any ideas?
    Serial no. 605040054
    #295211
    Re: Hotpoint WD420G
    Have you looked at the error code thread?
    #295212
    Re: Hotpoint WD420G
    if u look in known fault codes you get
    light 3 & 4 flashes
    f03 lights 3&4 Ntc fault
    info is on site if you look around
    hope this helps
