hotpoint wd420p
  • #37717
    A1phil
    hi about to replace control board on hotpoint wd420p do these like the wma need programming if so where do you get codes
    plus two of the edge connectors are different a two block blacks and a four block two blacks two orange thanks phil
    #256154
    helo_75
    well
    there are two different boards
    one has a j10 connection, the other doesnt
    now, no they dont programme like a wma, theres an eprom slot on the pcb, youll need one
    few variations on eproms
    is it hot and cold fill / cold fill/ does it have a flushing valve on the heater box?
    the later ones had 2 cold fills, and a flushing valve
    u need to know whther it has a j10, and the above things need checking to get the right parts
    hope this helps
