hi everyone looked at this last week and the dryer thermostat was o/c so ordered a new one when i went to replace it noticed it was different .the old one is a 145 deg with a yellow spot and the new one is a 160 deg with a red spot is this correct as i dont see any other one listed.i even looked at the apartment next door where the other type of box is on the dryer and it has the red spot stat.Can anyone answer this thanks.
Niall
thanks for reply Jim. does it not matter that the old one has a yellow dot could it be the old type of heater box or does it matter now and the new toc works with both.i just want to make sure that it is the right one.thanks Niall
it could have been repaired by someone else before i dont know but i will fit the red dot toc and see .is the sleeved microtemp device part number Thermal cut out Cable (5031681476865).if so then it does not have this. the serial number on the m/c is 37143634.
thanks Niall
