hotpoint WD420P(37143634)
  • #48521
    Galway
    Hi all,
    this w/d is not draining but sump is clear and pump ok.is the pcb a common failure in these and which pcb is for this m/c the mk 4 or mk 8 or will i have to go back and check it out.
    thanks
    Niall
    #296804
    johnnyj
    Re: hotpoint WD420P(37143634)
    Looks like the module, you will need a C00254535 module plus wiring to convert 1605611 and 1605610, i would bodyswerve that one if it was me, i’ve done a few recently been a right pain, the pair of them.
    #296805
    MickGeorge
    Anything that has a rear module fitted from the Indesit stables I always check and tighten the connector blocks especially if i suspect a pcb fault
    Had a simlar prob on Indesit m/c which turned out to be bad connection giving no pump prob. Only found it after sent pcb away for test and came back ok.
    But you may have done this already
    Mick
    #296806
    Galway
    ni checked all connections all ok .i have now ordered replacement board.
    so fingers crossed.
    thanks
