Hotpoint WD440
  • #59878
    TheSpinDoctor
    Hi all.
    I have one of these which needs a new dryer fan motor. Any idea on a part number & cost. Also, any advice on it’s fitting would be appriecated.
    There also appers to be a coin stuck in the tub & I suspect it may be under one of the drum paddles. Can these be removed & if so how?
    Thanks in advance.
    Happy New Year.
    TSD.
    #339913
    Re: Hotpoint WD440
    Up to date code 54 fan motor is a C00115553, after serial number 60612.0000 its a C0098711. List price is around £51.00 ex vat.
    You don’t need fitting instructions, just follow your nose and remove the heater box complete. The motors themselves don’t fail that often, its usually the fan coming loose and jamming on the heater box itself.
    NB. The fan locking nut is a left hand thread. 😉
    Drum lifters are exactly the same as WMA ones, push a thin terminal screwdriver down the third hole from the front to depress the locking tab and pull the lifter forwards. Make sure you lift the tab back up before refitting.
    TheSpinDoctor
    Re: Hotpoint WD440
    Once again thanks for your help Jim. Take a bow! 😀
    #339915
    TheSpinDoctor
    Re: Hotpoint WD440
    Apparently, the serial number is: 703190264. Does that look like a serial number or is there another number I need?
    #339916
    johnnyj
    Re: Hotpoint WD440
    Thats the ser n/o 9 digits, 1st 3 relate year and month of manufacture yours was made in march 2007, jj
    #339917
    TheSpinDoctor
    Re: Hotpoint WD440
    Cheers for the info guys.
