Hotpoint WD440
  • #60175
    dave-m
    Just had a look at this machine this eve.
    Customer says it wasn’t emptying so he took out the pump himself (after watching a repairman do it a few years back!!!) and cleaned out a lot of stuff, put it back together and hey presto..it worked….once!
    When he then put it on to dry clothes that night he came down the next morning to find the machine still on but idle and half full of water. He put it on to spin and it emptied but did nothing else.
    So, I looked at it this eve and it won’t spin. Connections good, Brushes good, motor good and board looks clean. I didn’t have the fault code guide so I couldn’t put it into test mode to see if it shows up anything.
    I’m going back tmro to have a longer look and to put it into test mode.
    I’m currently trawling through all the threads on these but maybe someone has an answer that I can’t see yet.
    I know the boards give trouble but is there something else I should be looking at, something maybe I’ve missed?
    Ta
    cornwell40
    Re: Hotpoint WD440
    I’ve had these where they have taken out the board due to water leaking from the condenser area when they have a partial blockage.
    TC
