Hi went to use my washer, turned on power switch but nothing else worked. No start light or anything just dead. Any ideas where to start looking for faults? Only the power light is on no other fault lights showing?
Thank guys
Could be a couple of things, firstly check motor brushes, if they are too short then the machine wont start, if not that, check control pcb and make sure start switch in properly soldered to board, they have a habit of dropping off. Hope this helps.
Cheers
Ricky
PS Also check buttons aren’t all gummed up and stuck in.
Hi Ricky thank you for your response, do you know any decent videos on youtube to show me how to change the Brushes and get to the pcb on this model washer?
