hotpoint wd440
  • #23658
    timdowning
    Need a cold valve for this machine. Connect show it as a 4 port valve.
    I’m sure i saw this model with a converted valve set-up. The modification was done by hotpoint under guarantee. I seem to remember one of the hoses was done away with, i think from valve to top of blower motor housing.
    My question is;
    Is there such a modification and if so can i fit a triple valve instead?????
    #198947
    Re: hotpoint wd440
    The mod is for the later dryer heater box, you just isolate the flushing valve, if machine still has old type heater box with 4 way valve then that is what you need. A much better option although more costly would be to do the dryer box conversion together with a 3 way valve, always assuming the valve outlets point in the correct direction, no 3 way valve listed, only the 4 way one.
    timdowning
    Re: hotpoint wd440
    The wd440 i saw, with the modified valve, had the old type heater box. I actually changed the heater box to the new type because the old heater had failed. So hotpoint shouldn’t have isolated the flushing valve without changing the heater box?
    (My heater box had no valve modification sheet with it)
    #198949
    effzedarr
    Re: hotpoint wd440
    Hi there ,just been outside in the rain,raking about in me van for this hope it helps 1605222 is the part# for the 3way valve on a wd440!
    I did one about 3months ago still kept the old packet & valve [use old solenoids in emergencies].
    regards Chris..
    #198950
    timdowning
    Re: hotpoint wd440
    Thanks for that Chris. Went to call this morning and fitted triple valve, 168985. Fits nice and seems to be ok. (elimination of flushing hose already carried out by hotpoint 6 months ago). Hope you have dryed off.
