Hotpoint wd440 eprom setup
  • #35448
    snig
    Fitted a new module and eprom today but getting F09 code showing. eprom/ setup fault. Have double checked connection but can see nothing wrong. Any ideas. Original board blew due to suppresser short.
    #246547
    helo_75
    you did buy a programmed eprom, didnt you?
    #246548
    snig
    Re: Hotpoint wd440 eprom setup
    Yes, this model has several eprom options, this one is cold fill only and therefore available, but some i see were no longer available and you had to buy a blank one and programme it.( VERY helpful )I had advised the customer to use his 5 year warranty but he wanted me to do it. I’m beginning to wish he hadn’t. Has anyone got a wiring /connection diagram for mark 4 board just in case i’ve reversed a connection.(they are not all keyed. some are single amp tags and we all no it can happen to the best of us)
    #246549
    helo_75
    id be surprised if wiring it up wrong would cause an eprom set up error tbh
    its usually the eprom
    #246550
    lerch
    For this model there is at least 3 eproms depending on which dryer version you have. (there are 3) then if it is cold fill or hot/cold fill. ๐Ÿ™
    On some the colour of the label on the motor can make a different to. ๐Ÿ‘ฟ ๐Ÿ˜ฅ
    #246551
    Hi this is my first post, been doing a lot of reading, whenever i get a hopint indesit, which is a lot of the time!
    And has a board fault i always use emw and px the old board they come with a yearโ€™s g/tee and pre programmed so just plug them in no aggro and helps keep the repair cost down, whenever i take any boards off i use a marker pen and mark up so i donโ€™t forget how it was,
    Hope is of help for other jobs like this,
    canufixit
    hi to all ๐Ÿ˜€
    #246552
    snig
    Finally resolved problem which was incorrect eeprom. this one is for new heater box design, i didn’t realise there were so many options. Thanks for the advise.
    Although still unsure what the difference is between heater boxes should i be unlucky enough to come across another one?
    #246553
    helo_75
    the three in circulation are
    original – machine was hot and cold fill , had a 4 way valve, and had a flushing valve with a filter at the back of the box
    second wave – hold and cold valve, 4th valve and filter removed – heater box reverted to merloni spiral element and in line thermal fuse
    3rd revision – cold fill only , flushing valve was re introduced
    the bit you need to look for is whether it is h+c fill, or just cold fill and if it has a 4 way/3 way valve and a filter at the back of the box
    does my head in, remove it – re introduce it, remove it – reintroduce it
    none of em work well anyway
    does this clarify anything?
