hotpoint wd440 F10 Pressure switch not sensing
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries hotpoint wd440 F10 Pressure switch not sensing
  • #63794
    nelson
    I have the above machine displaying a F10 fault. The machine washes fine but displays the fault during the rinse cycle.
    I have checked and tightened all the connections at the module, cleared and cleaned the sump hose and pressure chamber and replaced the pressure switch, but the fault still persists.
    Can anyone help me?
    Cheers
    #355017
    Re: hotpoint wd440 F10 Pressure switch not sensing
    nelson wrote:Can anyone help me?
    Could be either: –
    Slow fill/inlet valve time-out probs
    Button or coin in drain hose/pump/sump block probs
    or Module/or the connections to it
    #355018
    nelson
    Cheers Martin,
    It always seems to go into fault mode as it is draining out on the rinse program. It is filling up nice and quickly, I have cleared the sump hose and pump, but in all honesty it seems to drain pretty quickly anyway, and I’ve tightened the connections to the module, so it looks like it may need a new module :rolls: fantastic.
