hotpoint wd440 – F8
  • #35946
    nelson
    Hi all,
    I have to call to this one, customer says it has completed the wash ok but when on dry, the on/off button and high heat drying lights flash, this works out as f 08, heater relay. I have not come across this before. Is the relay on the main module? if so does this mean replace the module or can you replace the relay?
    Thanks for any help. 😕
    #248815
    Re: hotpoint wd440 – F8
    Can be heater relay….. Can be wiring…….. Almost invariably a board fault………
    Relay is soldered to the PCB anyway.
    Crhis.
    #248816
    nelson
    Cheers Chris I’ll check it out.
    #248817
    hotpnt
    if you go for a module, make sure you get the correct eeprom too, many different types for washer dryers, depending on hot/cold fill, cold fill ony, plus 3 different types of dryer,
