hi could anyone help with the following problem that we have.
hotpoint wd440 after 40 min aprox the machine locks up with the reduced crease light on as well as ther time saver and on/off light.
Are the lighs on or flashing? If they are flashing, count the left hand vertical neons from the top down and refer to the Known Error Codes thread at the top of this forum.
From memory it will be lights 2 & 4, fault F05, pressure switch stuck on full. Partially blocked sump hose, faulty pressure switch etc.
