Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Hotpoint WD440 G – flashing lights, fails to drain
- This topic has 9 replies, 2 voices, and was last updated 18 years, 10 months ago by
ormy.
June 19, 2007 at 11:57 am #28270
ormy
ParticipantA problem has just recently occured on my 18 month old Hotpoint WD440.
Basically, after I ran a D programme at 40 degrees, after it presumably finished:
– the on/off button was flashing
– the Reduced Creases (2nd bottom down) and Time Saver (4th bottom) were flashing
– the door was locked for some time
– the detergent drawer (left hand compartment) did not dispense during the wash
– a motor (i think connected to detergent drawer) was still running but the drum was notwhen i managed to get the door open after switching the appliance off at teh mains, it turned out that the water had not drained (maybe indicating teh programme didnt finish?). Therefore, i check the filter, drain pipe for any blockages but did not find any.
What could be teh problem? The electrics or drain pump perhaps? Do you recommend that i get Hotpoint to come out? I believe its £89 labour and free parts from reading on.
Any help would be much appreciated
June 19, 2007 at 4:23 pm #217573iadom
ModeratorRe: Hotpoint WD440 G – flashing lights, fails to drain
Fault code F05. Pressure switch stuck on full. Likely cause is a blockage or obstruction in in the pump itself if the filter cage is clear.
Jim.June 19, 2007 at 5:57 pm #217574ormy
ParticipantRe: Hotpoint WD440 G – flashing lights, fails to drain
is it easy enough to disconnect the drain pump and check / clear the drain pump and replace if necessary?
bearing in my mind i have already managed to clear the filter (thats the level at expertise that I am at!!)
Cheers for the advice so far
June 19, 2007 at 7:00 pm #217575iadom
Not to difficult, make sure the mains plug is out first, place a few towels on the floor. Pump will split if you cannot remove any objects from the inlet/outlet of the pump. Usual culprits, broken bra wires, hair bobbles, hair grips, etc. be sure to pull the filter right out of the rubber sump hose, anything down the side will cause this problem as well.
June 21, 2007 at 7:05 pm #217576ormy
cheers for all the help Jim.
Just done as you have suggested and was surprised how easy it was. There was an eyelet and tough material attached stuck in the pump but managed to safely remove it by opening it up.
Heopfully this will rectify the problem – just running a test wash through now so will let you know how it goes!!
Cheers
June 26, 2007 at 7:04 pm #217577ormy
New problem has now occurred since I did the fix last Thursday.
Everything went according to plan and we managed to perform 3 wash programs with everything going ok.
Saturday morning, i ran the drying programme for 90 minutes. When i came back home, all the electricity was off and i narrowed this down to the washing machine.
What will be the cause of the machine breaking the circuit bearing in mind my recent ‘repair’.
I am not sure when during the cycle it occured but it seemed to be at the end as the clothes were dry and still warm.
Your help has been appreciated so far
June 26, 2007 at 7:06 pm #217578ormy
..by the way i have checked the connections at the back, replaced the 13AMP fuse in the plug but the same problem occurs.
i havent disconnected the pump again as to be honest i would not know what i would be looking for
Cheers
June 26, 2007 at 7:21 pm #217579iadom
If the machine did three washes after you cleared the pump then as long as there is no sign of a leak this could just be a coincidence. The only way to be certain is to check all the components with a multimeter or meggar for short circuit or earth leakage.
June 26, 2007 at 7:36 pm #217580ormy
it was actually 2 washes, come to think of it.
there is slight damp patch on the floor but cant see any visible signs of leakage around the drain pump and drain pipe. My concern is that the area in the machine (and indeed the coils on the pump) would have been wet from when i had to solve the original problem.
would it be worthwhile disconnecting the pump again to check this (or perhaps check something else??)
Cheers, much appreciated
June 26, 2007 at 9:47 pm #217581iadom
All I can suggest is that you look very carefully for any sign of leaks, a blast with a hair dryer will often be enough to dry out anything you may have accidentally got wet.
