Hotpoint WD440 Just wont stop washing
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Hotpoint WD440 Just wont stop washing
Viewing 15 posts - 1 through 15 (of 18 total)
  • #43087
    qhussai33
    it just wont stop, because its a single feed we thought it might be the thermostat but just called qualtex and there isnt a thermostat for the washer bit only for the dryer part!
    So is it the thermostat? or something totally different ?
    #276020
    helo_75
    itll be the heater , comes complete with THERMISTOR, but you might wanna make sure its not syphoning
    #276021
    qhussai33
    Re: Hotpoint WD440 Just wont stop washing
    the complete heater? that wont be cheap will it?
    what do you mean by syphoning?
    #276022
    helo_75
    if the drain hose is pushed too far down the frain, itll neve complete a cycle, although youll normally get an error code.. the heater is the only fault that doesnt give ane error
    #276023
    helo_75
    qhussai33
    well it doesnt give an error code as this model doesnt have a digital screen, but the machine that was plumbed in before was working fine and they put the gutter pipe in as much as they did with the last one.
    #276025
    qhussai33
    and also we ran it on the cold wash only by leaving the temperature knob off and the cycle worked fine, but when we turn the temperature on then it doesnt stop.
    So do these machines not have a thermostat?
    #276026
    helo_75
    so the heaters faulty!!
    it doesnt need to have a digital screen to display an error code
    can i ask how long youve been doing the job
    they have a thermistor, and if it was faulty, it would show an error code
    #276027
    qhussai33
    sorry but im posting this for one of our engineers, thats why i dont have a clue 🙁
    #276028
    lerch
    Try using a meter and check the heater and also the ntc. 👿
    #276029
    qhussai33
    so is this a common fault with these hotpoints?
    ps just a thought would putting it onto a hot feed not resolve the problem?
    #276030
    lerch
    If the heater is faulty and the water on the hot feed comes in at 50c and you want a 60c wash it is not suddenly going to start working just buy a heater and stop being cheap !! 👿
    #276031
    Despite having two valves, the machine is probably cold fill only. Heater is p/no C00112578 from your wholesaler of choice.
    helo_75
    putting a hot feed will make it abort during rinses
    im not posting on this thread again, i think its a wind up
    #276033
    qhussai33
    right new heater it is
