Hotpoint WD440 keeps blowing fuses
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Hotpoint WD440 keeps blowing fuses
  • #75096
    crisp24
    I have a Hotpoint WD440 washer/dryer which has been working well up until a couple of days ago when the fuse blew on the mains plug shortly after a wash cycle. Now, whenever I plug it in the fuse in the mains plug blows instantly. I have removed the lid and I can see that what I believe to be the capacitor is blackened and smells of smoke. I hoping some kind individual might be able to help me fix this.
    Thank you in advance!
    #393830
    Re: Hotpoint WD440 keeps blowing fuses
    Capacitor??? Do you mean the mains filter, where the mains cable comes into the machine at the back? If so then you will need a new mains lead and filter, it comes as one unit.
    Part number..C00203264
    #393831
    crisp24
    Thanks for your reply. Yes. Sorry. It’s the unit that the mains lead goes into at the back of the machine.
    #393832
    madangler1
    You may also need to cut off the plug and fit spade connectors as it normally melts the plug as well, always on the neutral i find as well.
