I went to the above washer dryer the other day.Customer said the 2nd light flashes(Pressure switch problem), the pipe from pressure switch had come off.
Put it back and then it just drains and takes water on any programme and when I switch it off from On/Off button it still drains.
I have changed the pressure switch, no blockage,pipe is OK, no burnt parts on the module.
It should not drain while it is off even pressure switch had a problem??
Really confused about this one.Or is it the case the module is gone?
Regards
