Hotpoint WD440 runs for 3 or 4 mins then trips error code…
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Hotpoint WD440 runs for 3 or 4 mins then trips error code…
  • #57681
    SteveATY
    It seems to be showing error code 01 which is light 4 flashing on its own with the on/off light.
    This is called ‘triac error’…
    When the machine is running the drum is only turning clockwise during wash and spin cycles (until it faults and stops).
    What is the likely outcome? New control board?
    Cheers,
    Steve.
    #331949
    Re: Hotpoint WD440 runs for 3 or 4 mins then trips error cod
    check motor to earth
    look at board for bad solder joint around relays
