This fella turns on as normal but pressing start button has no effect.. nearly. Pressed it about ten times in a row & suddenly it sprang into life, locked door & started prog.
Anyone know if the cure is as obvious as it seems; ie, new front panel needed? The start sw does have a normal feeling ‘click’ & ive checked the ribbon cable at both ends.
Learned to take nothing at face value with these Indypoint bags of sh*t :rolls:
Cheers Phidom, yeah the tiny surface mount switches can fall off with over enthusiastic prodding, happens on LGs too i’ve found. Will prob return with a facia panel, job is in back of beyond of course :rolls:
