HOTPOINT WD440P
  • #47076
    Dapman
    Can anyone help with this problem – I attended a Hotpoint WD440P washer dryer and when you switch the machine on, all the lights on the facia panel flash continually.
    The only way you can switch the machine off is at the plug.
    Also, the machine will do absolutely nothing.
    I assume its probably the main board, but I haven`t seen this fault before.
    Cheers Dave
    #292232
    wilf
    Re: HOTPOINT WD440P
    have you checked the display board to see that the minature switches are intact?
    wilf
    #292233
    Re: HOTPOINT WD440P
    All lights flashing is quite common and is virtually always a PCB failure. 😥
    Its even worse if the lamos arfe flashing. 😉 😆
    Hope P45 doesn’t read that last bit. 😀
    Dapman
    Re: HOTPOINT WD440P
    Jim Do you know if the type of pcb has to be programmed
    #292235
    Re: HOTPOINT WD440P
    They all have these days, smart card, card reader, the lot. 😥
