Hotpoint WD440P Door locked and dryer lights
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Hotpoint WD440P Door locked and dryer lights
  • #43944
    Bernie
    Hotpoint WD440P Door locked and dryer lights.
    Dial to anything switch on, dryer light comes on then door locked lights, (not flashing) dryer starts to run if you try and cancel the bottom three option lights come on also (not flashing) dryer continues to run.
    Only way to stop it is to switch it off, also if you switch it on and then turn program dial to anything and without pressing start button the same happens, dryer light comes on then door locked lights, (not flashing) dryer starts to run.
    I have looked in the error codes there is nothing listed for the bottom three option lights, plus they should be flashing.
    Anyone have any suggestions
    Thanks Bernie
    #279170
    Re: Hotpoint WD440P Door locked and dryer lights
    the only fault listed fot lights 2 3 & 4 is heater relay and as you say it normally flashes
    what worries me is you say it starts up with the same thing each time
    think i would ring emw of if he is online he may help think i am beginning to suspect board and emw may be able to test
    hope this helps
    Bernie
    Thanks for help Dave but there are 5 option lights on the left so its 3,4 & 5 that come on.
    Thanks again
    Bernie
    #279172
    Bernie wrote:Thanks for help Dave but there are 5 option lights on the left so its 3,4 & 5 that come on.
    WD440’s do indeed have 5 option LED’s but yours ain’t listed here I’m afraid. 😕
