Hotpoint WD440P lights flashing
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Hotpoint WD440P lights flashing
  • #34759
    adzh
    my Hotpoint WD440p Is playing up it is flashing the no/off light, the drying high heat and the Time saver light.
    I have looked for a fault code with no luck please help
    Thanks Adam
    #243911
    Re: Hotpoint WD440P lights flashing
    Can you give us the left hand lights by number from the top down please.
    adzh
    the left hand lights from top No.1 And No.4
    Thanks Adam
    #243913
    Problems I’m afraid. F09 points to an eeprom setup error. The Indesit electronics in this machine are very unreliable. It may be possible to re write the eeprom but you will have to get an Indesit Company engineer to do that, they will not allow the independent trade to have the software.
    There is a strong chance they will replace the module & eeprom anyway.
    Take advantage of your five year parts guarantee and phone the Indesit Company, all parts will be free, you will only pay the labour, which although high is less than the cost of the parts that you will like as not need.
    kelland
    you can get pre-written eeproms, i use them all the time
    #243915
    Most of the trade members at UKWG’s are well aware of the pre written eeproms, however if the original is soldered in then this is no easy DIY task, also there are at least three different eeproms for this model alone.
    If the OP is a wizz with a soldering iron and is competent at board level repairs then it is worth the risk, if not then my original advice stands.
    Bear in mind that the original eeprom will be a little one – any replacement is likely to be a “large” one designed to clip into a holder rather than be soldered anyway.
    Deep joy……
    adzh
    Hi thanks for the help but now the top two lights are flashing!! help
    #243918
    08709 066066 😉
