Hotpoint wd440p modules
  • #26004
    helo_75
    im fed up of hotpoint
    the original pcb was part number c00091907
    that parts now obsolete
    it now comes as c00140356
    trouble is, it fits the washers ok, but on the washer dryer one of the plugs dont fit
    ne1 know the answer?
    hotpoint have given me a part number for the board with connection j10 missing, but im not sure itll work
    ne1?
    #208431
    Re: Hotpoint wd440p modules
    Do you not have full access to Emit/Partfinder? Someone at our meeting mentioned that it had not been updated for a while, I thought it was updated overnight?
    indespoint
    Did the original one you need to replace have J10 connection? if so C000143056 is the correct board
    If the board they have supplied you with does not have J10 do not fit it!!! The board you have is it C00145013 by any chance?
    What they have done is changed, for a 3rd time, the dryer heater box. The latest version has now got the hot flushing valve back on it hence the change of board. If its any consolation it confuses me and I work for the company
    Jeff
    #208433
    helo_75
    well, indespoint, the 5013 pcb is the one tech at merloni suggested
    he quoted summink about the serial numbers, but as usual, the trade arent privvy to that just yet
    as you know, the 91907 fits a large number of machines, and quite often, they fit, certainly all the washers
    the problem becomes on some models, not all
    oe of the connections on the board, it just doesnt fit
    we’ve been advsed by merloni not to solder the connections,im sure that would work
    im just waiting for the pcb to come, and ill compare.. thing is, since the 91907 is now defunct, i cant compare it to the original, only the so called replacement that doesnt fit!!!
    doin my head in to be honest
    it hasnt happened loads of times, it just the odd one
    ill keep you posted
