Hotpoint WD52 Washer Dryer
  • #7838
    BobHope
    Hi all,
    anyone got the timer wiring diagram for the timer conections, customer has removed the timer without noting the connectors, the keyway plugs i can sort but there is three loose spade connections that can de connected incorrectly, they are located on the bottom front of the timer.
    Cheers Bob.
    #125411
    SparkyP
    Re: Hotpoint WD52 Washer Dryer
    Hi Bobhope
    The connections from front to back are Grey wire on A, Black wire on B and Blue wire on C
    Sparkyp
    #125412
    BobHope
    Thank you Sparkyp,
    i will wire the timer back up tomorrow and then tackle the no motor action problem that the customer first reported. its not the motor or carbons as i checked them on the last visit, dont you just hate follow up calls after joe bloggs down the road has had a go.
    Cheers Bob.
    #125413
    clyde
    Have a quick look at the fuse between the timer and motor, its a forgotten favorite! (last fuse i had blown was wiring rubbing/shorting out on the motor)
    Clyde 8)
