Hotpoint WD61 In line motor fuse
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Hotpoint WD61 In line motor fuse
  • #64283
    goosegreen
    Could anyone let me know the rating and type of the above? Connect list the fuse and wire unit but are showing no stock and I have never come across a blown one before. Motor and brushes fine but signs of chaffing on the motor loom.
    Goose
    #356611
    Re: Hotpoint WD61 In line motor fuse
    FF01380 8amp microwave fuse from CPC Farnall will fit.
    Only in packs of 10 though.
    PM me your address and I will stick a couple in the post for you.
    I have had them fail when an item of clothing has got jammed in the drum but chafing wiring is the most common cause.
    goosegreen
    Cheers Jim
    Had a bag of them on the van 😡
    Thought best to make sure
    Goose
    #356613
    It should actually be a 6.3 amp fuse but I have never had any comebacks after fitting the above. 🙂
