Hotpoint WD61 motor
  • #39499
    claude
    Trying to get the main drum drive motor off my WD61.
    Seems designed not to come off, due to the oversize lug at the rear mount to the plastic body of the drum housing.
    Is it possible to remove whole motor, or do you take motor apart in-situ? If so, how is it done?
    Thanks.
    #262624
    Re: Hotpoint WD61 motor
    There is no ‘oversized lug’ Its just got a little burred over on assembly.
    Not a lot of room in there but if you have removed both of the bolts then it will come off.
    A flat bladed screwdriver is one of the things I use to prise them off.
    Its just a bit awkward thats all.
    If you only want to change the motor brushes then you do not need to remove the motor at all.
    claude
    Thanks Jim, much appreciated
