Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Hotpoint WD61P 185 deg Dryer Stat.
- This topic has 13 replies, 6 voices, and was last updated 18 years, 9 months ago by
Turbo.
June 29, 2007 at 7:08 pm #28593
Turbo
ParticipantCan someone help me on this one please.
Went to fit new one shot stat to this machine today (1605635) but although is was the correct temp rating it was physically larger than the one it was to replace and would not fit.
Any help would be good thanks.
Turbo.June 29, 2007 at 7:13 pm #219052Penguin45
ParticipantRe: Hotpoint WD61P 185 deg Dryer Stat.
Cut-out is 1600870.
June 29, 2007 at 8:05 pm #219053admin
KeymasterRe: Hotpoint WD61P 185 deg Dryer Stat.
Also check the fan is running correctly and that there is no fluff build up
Bryan
June 29, 2007 at 8:09 pm #219054Turbo
Thanks Chris, just tried putting that number in to Connect system and it comes up 1605635 again but I am sure you are right having looked at a picture in the Parts Centre Cat, will ring the Rep and tell them to sort it out.
June 29, 2007 at 8:12 pm #219055Turbo
Thanks Bryan blowing a gale down the old chimney 😆
June 29, 2007 at 8:28 pm #219056Bryan
From memory the last time I did one of them , there was a modification leaflet instructing you to bend the metal bracket slightly in order to accomodate the new thermostat.
HTH
Bryan
June 29, 2007 at 8:46 pm #219057Turbo
Thanks may have to go back and have another look.
June 29, 2007 at 9:46 pm #219058Bryan
ParticipantJune 29, 2007 at 9:47 pm #219059iadom
ModeratorRe: Hotpoint WD61P 185 deg Dryer Stat.
Bryan is correct, this replacement stat needs the bracket bending back to fit, there should have been a leaflet with the new stat.
Nice link Bryan, hadn’t seen that post from Martin.
8)
Jim.June 29, 2007 at 9:54 pm #219060Bryan
Just thought I’d credit Martin so he didn’t see it as a bit of plagiarism 😉 🙂
Bryan
July 1, 2007 at 10:32 am #219061bobokines
Don’t miss the reason for the stat failing. Normallly it’s due to an earth fault on the harness by the motor. The orange wire IIRC
Bob
July 1, 2007 at 6:02 pm #219062iadom
Seen more fail due to broken wire to fan motor. The one you mention Bob is common with FHP motor.
July 1, 2007 at 6:34 pm #219063Bryan
Turbo wrote:blowing a gale down the old chimney 😆
I presume this meant there was no problem with the fan :).
Bryan
July 2, 2007 at 6:55 pm #219064Turbo
Thanks for all your help on this one guys, new stat now in place after a bit of work with the pliers. Found 2 broken wires near the motor plug which I have fixed.
Thanks again
Graham -
