Hotpoint WD62 – thumping like a demented rabbit
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Hotpoint WD62 – thumping like a demented rabbit
  • #19890
    Brett07842G
    I have a hotpoint WD62 washer/dryer that has started to bang very loudly when in rinse and spin.
    Its just like the banging you get with an uneven wash load but much much louder and lasts for longer.
    I wondered whether this is something I could fix myself or whether I needed to call someone out.
    Please help.
    #184907
    clyde
    Re: Hotpoint WD62 – thumping like a demented rabbit
    all depends how technically competant you are,
    unplug the appliance :zap:
    take the lid off and have a look inside, see if there is anything obvious first
    #184908
    phil59
    check up & down movement on drum could be bearings?
    #184909
    Simon46
    Or the condensor unit on drum rear is loose or the 2 top tub springs snapped.
    Regards
    Simon
    #184910
    Or the drum support, so many possible causes, most of them are not the type of job that I would class as easy without the required tools and experience. 😉
