Re: Hotpoint WD63
There is a spin during the drying cycle on later WD models.
If the machine has an FHP motor, check the wiring harness where it is lashed tightly to the front of the motor. The motor bracket does chafes through the harness at this spot and will often blow the dryer TOC. If it is chafed then repair the wiring and bend the motor bracket back with pliers.
At the same time check where the harness is secured to the cabinet near the motor.
