Hotpoint WD63 No Power
  • #28395
    Tocano
    My Hotpoint WD63 washer/dryer was in the middle of a drying cycle when it suddenly stopped, no suspicious noises etc just stopped.
    I have checked for power at the mains wall socket this was ok, also checked the fuse in the washing machine plug again ok. The power Light on the machine does not come on.
    Any suggestions please
    #218179
    Re: Hotpoint WD63 No Power
    On/off switch or door interlock would be my favourites.
    Power off if investigating.
    Tocano
    Penguin45 wrote:On/off switch or door interlock would be my favourites.
    Thanks for the response.
    I have changed the door interlock but still same.
    Have removed the ON/OFF switch and tested with a multimeter.
    Pins 4 & 6 close (ie short circuit) when switch is in the ON position but pins 3 & 5 remain open circuit in both ON and OFF positions. Could you confirm that this indicates a faulty switch.
    #218181
    Yup, switch has failed. Get yourself one of these:
    http://shop.ukwhitegoods.co.uk/product_ … cts_id=539
