Re: Hotpoint WD64 – leaking
Unless you have a pressurised hot water inlet system I cannot see why that would cause the dispenser to leak?
The most usual cause is almost always due to either too high a water pressure or the dispenser nozzles are clogged/scaled up? If you have very high water pressure (on either hot or cold supply) then simply turn the tap down a bit to stop it. 😉
If pressure is not the problem, then take the soap drawer out and give the cavity inside a good clean with a soft brush. Plus clean the soap drawer thoroughly before putting back in!
Make sure the machine itself is level or better still, sloping a little front to back 💡
