Hotpoint WD64 stuck in rinse
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Hotpoint WD64 stuck in rinse
  • #72563
    twicknix
    Visited this machine and found it was stuck during the rinse. Not everytime but happens every now and then. Checked water fill ok, insulation ok, brushes ok, drain and motor action ok, timer seems to progress ok.
    Timer circuit board looks clean, no signs of blowing. Can’t think of anything which caused the rinse to stop and yes the “rinse” hold button is not activated.
    Any ideas?
    #384901
    Muv
    Re: Hotpoint WD64 stuck in rinse
    Faulty rinse hold switch?
    Heater relay contacts welded closed
    Sump filter blocked..
    Elderly cold valve with a touch of prostatitus?
