Hotpoint WD640 – Fault code F-03
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Hotpoint WD640 – Fault code F-03
  • #17204
    pdac
    I purchased a new Hotpoint WD640 washer dryer last weekend but following first use the digital display shows F-03. I cant find what this code means in the instruction manual or the hotpoint website.
    Any help would be much appreciated
    #173327
    Re: Hotpoint WD640 – Fault code F-03
    It could be a fault caused in transit if this is the first time you have used it.
    F03 is supposed to indicate an NTC fault. You need to contact Hotpoint service to attend to this machine. It has Indesit electronics in it which are prone to all sorts of faults, some which don’t even match the error codes.
    #173328
    pdac
    thanks for that, I have called service for a visit. By the way, what is an NTC fault?
    #173329
    The NTC is an electronic temperature sensing device, this machine has one for the wash and one for the drying cycle. F03 is the wash NTC.
