Hotpoint WD640G Washer Dryer F-13 errors parts
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Hotpoint WD640G Washer Dryer F-13 errors parts
Viewing 5 posts - 16 through 20 (of 20 total)
  • #255267
    Re: Hotpoint WD640G Washer Dryer F-13 errors parts
    Be reasonable, there are many millions of parts out there. 🙂
    We can only list the more common ones but can obtain any part that is available at a fair price.
    Drop an e-mail to that address with the part nubmers you have been given and you will get a reply with regard to costs etc.
    hotpnt
    as for the re-programming, it will depend which one you are taking off & which one you are fitting, there are 4 different variants for your model,
    #255269
    samueljames
    I just assumed if the bits were not listed on whitegoods they did not sell them 🙁
    how would i know what assembly would work just i was thinking it maybe easyier just to replace the lot and fix it properly if possible.
    as i think i have said before it is the type with the thermal cut out under the metal shield that you can only access after removing the assembly and heating element.
    why is reprograming needed as the connections are all the same by the looks of it and i thought the element wattage was the same also.
    or have hotpoint just made it too clever lol 🙂
    thanks
    sam
    #255270
    hotpnt
    if its identical then no problem, just that some of the replacements also involved changes to the wiring & water valves too,
    #255271
    samueljames
