Hotpoint WD64P Motor (rear plastic fixing)
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Hotpoint WD64P Motor (rear plastic fixing)
  • #63635
    MickGeorge
    Hi Folks
    Been to this today and the rear motor fixing is broke on it – looks like the motor might have taken a wack from an off ballance load.
    Has anybody got the part no for the rear plastic fixing for this – it is the fixing that fits into the rear motor bracket with a metal pin that expands it and then pushes into the hole on the tub bracket.
    I have put this on this forum insead of the Parts one as when I searched I can only come up with the metal bracket(1600064)that, if memory serves me. screws to the tub. A Part No inquiry to Connect they are coming up with the same bracket as well. Have they done a mod to this and if so what is it and how would you fix this bracket to the tub? I thought the metal one fitted a different outer tub design?
    Mick
    #354375
    clivejameson
    Re: Hotpoint WD64P Motor (rear plastic fixing)
    Hi Mick have a look HERE
    HTH?
    #354376
    MickGeorge
    Thats the one – thanks Clive – looks like it is a special order job from either Connect or Masterpart 🙁 Qualtex not even listing the part.
    Many thanks
    Mick
