Hotpoint WD71 Door open
  • #56333
    paul161201
    My machine will not start its seeing the door open. I believe its the interlock which is coursing this fault. To bypass bypass the interlock do i connect the live and common together? Just to see if it is the interlock.
    #326942
    Re: Hotpoint WD71 Door open
    Not the safest thing to do given how cheap a new door interlock is, we will not advise anyone to bypass a safety device.
    Given that your machine has fully electronic controls there is a very good chance that the doorlock has failed and done serious damage to the electronics.
    #326943
    paul161201
    It just a temp repair to see if the PCB still works
    the circuit board has blow a track which i have repaired
    I
    So do i just join the Live and common together
    thanks
    #326944
    iadom wrote: we will not advise anyone to bypass a safety device.
    :rolls:
