Display showing E30 fault (motor issues). This machine runs an FHP digital motor. Changed the worn brushes – they were low but not completely out. The motor checks out with a test meter and the loom seems fine but still E30. 😕
I have not known a PCB fail on these; but could no supply from the PCB throw up an E30? There is certainly no relay ‘click’ to be heard; just 10 seconds of pump then fault.
Any ideas?
Well if the motor and wiring (Rast connector etc) checks out OK then it must be the Power Module (Relay No 1 sticking or whatever) I would think….?? 😕
