Re: Hotpoint wd71 faulty power module ?
It does occasionally wreck the power board and sometimes the control pcb at the same time.
You can soon finish up well out of pocket on these if the board has gone.
I don’t think EMW repair or test these boards but QER do with reservations. 😉
Pull all of the connector plugs off both boards and carefully inspect the plug contacts inside the plugs, I have seen them burn off even though the plug looks fine.
