Re: hotpoint wd71 which panel ?
Wet Test .
Hold down buttons A & C then press On.
Press Start and machine should begin the sequence
There are ten steps in all.
Will fill in the details later, a bit pushed just now.
If it does go into test sequence, either let it run all the way through or press Cancel to clear.
Also worth examining the flexible circuit for any slight kinks, creases or other damage.
EDIT.
Step.
1. Fill cold for 40 secs, no drum action.
2. Temp controlled fill to 50° with normal action at wash speed.
3. Pause for 20 secs.
4. Fill from Fab Cond valve.
5. four tumbles of normal action at wash speed ( as temp reaches 50° display will show temp instead of step nymber)
6. Pump for 40 secs without agitation.
7. Pump & spin at 1000rpm for 30 secs.
8. Pump & Spin at 1200 for 10 secs.
9. Pump as drums slows to a stop.
10. Stop.
