Hotpoint WD71 will not start
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Hotpoint WD71 will not start
  • #53208
    MARIO
    Can anyone help with this machine a Hotpoint WD71will select prog. but when you press start button nothing happens . The door does not lock , does this sound like board fault thanks for any help.
    #314855
    Allsorts
    Re: Hotpoint WD71 will not start
    This could be the interlock itself or the little button on the board behind the start button
    #314856
    MARIO
    Ihave tried a new door lock so if it is the button on the board does it mean new board ?
    #314857
    Madmac
    Easy enough to pinch one of the option buttons & solder it on Mario. Or if you have a scrap board you can get one off that. Very common fault, repaired quite a few 😉
    #314858
    MARIO
    Thanks for that Madmac will go back on tuesday and try it.
    #314859
    burns
    very strong possibility the interlock has taken down the control board. remove the console and check for blown tracks behind the control board. very likely to have blown the track….
    #314860
    MARIO
    Printed circuit board not blown . How do I replace switch ? Do I peel plastic back to access switch or do I cut through it . Thanks for all replies
    #314861
    ? Plastic ?
    Not familiar with this model but I think you are looking at a tactile switch?
    Like one of these:
    RS
    but click the link that says, “more like this” as that one might be wrong size.
    So any plastic that’s getting in the way will have to be moved aside or cut through (though preferably not that, as its presumably protection against water ingress.)
    Note which way round old switch is mounted and put new one same way – (legs are bent. Or, if it’s surface mounted, there will only be one way of mounting it.)
    If you haven’t done electronic soldering before, search You-tube and get some tips first.
    Mike.
    #314862
    lasty
    Could be a blown chip ?? I post this on another reply but could be relevant .
    There is a 3mm x 2mm chip on the bottom left hand side easily distinguished by three prongs out the top and a single square plate attatchment at the bottom all soldered . check the chip for blown surface damage and of course track damage . Repair track damage and change the chip with one off a scrap board …….
    #314863
    Lasty, I’m not absolutely certain, but I think WD71 is an older machine which is pre – smd era.
    Mike.
    (Edit: So you can happily also ignore the reference to smds in my previous post!)
    #314864
    lasty
    leavemetogetonwithit wrote:Lasty, I’m not absolutely certain, but I think WD71 is an older machine which is pre – smd era.
    Mike.
    L.M.T.G.O.W.I – You are probably correct , bin a while since i`ve tinkered with an older WD , sorry for the confusion but thought it might help .
    #314865
    MARIO
    Cut a flap in plastic cover .Placed blade under the top part of switch and lifted out. Replaced back in position and now switch works . Thanks to you all for all the help on this job .
