Re: Hotpoint WD71P W/DRY
DAR01 wrote:No obvious damage to any of the boards, HELP
Mike,
Do double check the state of the boards for damages especially from water leaks from the door seal or holed front drum plate. Check the water heater and motor? If all checks out OK, send both modules (Power & Programme) to Tony at EMW for him to test:-
http://emwelec.co.uk/
Finally, always, but always, replace the Interlock whenever you have need to repair or replace a module (they’re cheap to replace yet cause so much grief in you don’t 😉 )
