Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Hotpoint WD72
- This topic has 3 replies, 3 voices, and was last updated 19 years, 2 months ago by
maltheviking.
February 3, 2007 at 12:41 pm #24738
maltheviking
ParticipantHelp!! this ones doing my head in! ๐ณ
Hot valve will not energise, valve ok, continuety of wiring from boards ok, Wet test works without energising valve, no error codes, I have substituted the control board (did not have a power board) no difference.
I have had the boards away to QER for test, no fault found.
My only suspect is the thermistor, anyone shed any light on to this problem before I go back to it.Mal
February 3, 2007 at 1:42 pm #203128philfish
ParticipantRe: Hotpoint WD72
dont know if i had to have a wild guess pressure switch?Have you meggared the cables might be fine with a continuety test but may brake down i know ther ain’t much current but could be going down to earth.but just guessing really good luck
February 3, 2007 at 6:30 pm #203129bobokines
Mal. I have some info on a pdf file that may help. Can I have your email address please,
Bob
February 10, 2007 at 10:20 am #203130maltheviking
Just an update to this problem you may find the results helpful.
Brief description of fault Machine would not energise hot valve even on โwet testโ, โspin testโ was also ok.
I checked all the wiring circuits and valves/ motor/ heater/ thermistor etc from the connections on the boards, no problem. ๐ My next thoughts were faulty boards although I was not fully confident, so I sent them of to QER to have them checked. Both came back with no fault found. ๐
On returning to have another look at the appliance I decided to check the thermistor and heater again by removing the front panel.
Thermistor checked OK but the heater gave and intermittent reading. I removed the heater from the drum and there it was, two โscoreโ marks! I checked the insulation of the heater, all OK but the continuity was intermittent. As we all know score marks on the heater is caused by the drum support failing ๐ก I had done a spin on the washer on my initial tests, up to full speed with no knocking. On withdrawal of the drum the drum support ended up in four pieces!!! I rebuilt the machine with new d/s bearings and heater. Fault sorted, happy customer. ๐
In all the years that I have been in this trade I have never been so deceived and will hold my hand up to it ๐ณWe are never to old to learn :rolls: hope this will help next time you find a similar fault ๐
