I am getting a E15 error code on this machine. I have checked the drain hose, the pressure hose and switch. The machine is draining, but not going into a spin.
Is that a wet test with a load of towels in it? Have you checked the wash heater? It may be a corroded spider rather than worn bearings which may have done the deed!
