hotpoint wd72n
  • #60468
    petalpop
    does anybody know the part number for the plastic vent that sits in the gap on the door seal to direct the air into the drum
    been to one today that has a bit broken off it and is ripping clothes
    #342320
    Re: hotpoint wd72n
    There are 2 parts, and I’m not sure which bit you need that makes up the nozzle into the tub? The most likely is C00202048 and you may also need C00198052 as well? 😕
    #342321
    petalpop
    Re: hotpoint wd72n
    cheers for that
    unfortunatly both parts come up as o/o/stock with no pictures
    so even if i wanted to i wouldnt know which one to special order 😥
    #342322
    Re: hotpoint wd72n
    Well C00202048 is the plastic vent that is screwed in position. So I guess thats the bit you are after? It’s the part that sits inside the drum and the most likely culprit to damaging clothes I would imagine.
    #342323
    petalpop
    Re: hotpoint wd72n
    yep thats the bit
    customer will like the wait with no machine i am sure
