Hotpoint WD860
  • #42300
    subs
    Customer called to say this machine goes through programme, drains and spins until display shows 001 min, and then starts filling again and he cant stop it.
    Done search but cant see anything like this.
    Any ideas.
    Subs
    #273039
    helo_75
    unusual theres no fault code
    id be checking the heater first
    then your lookin @ pcb ( surprise surprise )
    #273040
    lerch
    Re: Hotpoint WD860
    helo_75 is quite right I have had this alot of times and 99{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} it is the heater for some reason hotpoint put a feed though the heater on spin.
    #273041
    subs
    Re: Hotpoint WD860
    Cheers guys!
    Ill check it out tomorrow.
    Subs
    #273042
    subs
    Re: Hotpoint WD860
    Went to this machine today.
    Machine has a bit of water in it (customer had bailed rest out).
    The dimly lit display (cus says its always been that way since they moved in)shows 001. Turn machine on at plug on/off button lights up. Close door and machine locks and starts ramping up to spin all by itself without pumping out the little bit of water that is left in it. Pressing stop or cancel does nothing just bleeps. No buttons work at all. After machine finishes spinning it just tumbles. Screen still shows 001 and on button still lit but cannot turn off or cancel. If you turn off and on again from plug it does same again. Checked every thing, plus removed both boards and tightened everything up.The question is display board or main board or both?
    Subs
    #273043
    Re: Hotpoint WD860
    If the customer’s happy with a re-con module then it’s got to be EMW and return the one you don’t need.
    Mike.
    #273044
    Flyman
    Re: Hotpoint WD860
    Had this on a similar machine and it was caused by an earth fault on the motor.
